help setting up
Jean2121
I got 90% thru the setup when I saw that my address had an error message. I had to return to the 1st screen to correct the address but now when I try to get thru the first screen it says my SIM # is invalid.  I'm assuming it's becasue I'd already started to set it up. Is there a way to get the SIM to be accepted again?
@Jean2121 wrote:
Thanks again
Hope it works out for you next time you try:)
Jean2121
Thanks again
Jean2121
Thanks , I entered payment but that's when I noticed the address issue, I'll wait the hour and try again. Thank you
dabr
You should wait an hour and try again.  You can also try a different browser or/incognito mode.
If you never got to entering payment information, the fix is usually pretty simple.  Wait an hour and then try again.
