08-31-2022 03:58 PM
I have two other phones and don't remember my email and my bank card was changed and it comes out of my account automatically , 3 years I have never had to go on my account
08-31-2022 08:43 PM
Wow, 3 years and never had to log into My Account with 3 phones @Junior4 .
That is a good thing, I would say; assuming everything has been smooth sailing since activating.
Were all 3 accounts activated in-store; is it possible My Accounts/Self Serve accounts were never created?
Direct link to do this at would be here, to Create or forgot My Account email or password link.
Or, it may be a good idea to ask CSA to also ask to help you create My Accounts for all these plans/numbers as well, if you have opened a ticket already from methods above.
08-31-2022 04:02 PM
@Junior4 wrote:I have two other phones and don't remember my email and my bank card was changed and it comes out of my account automatically , 3 years I have never had to go on my account
To change/set the e-mail addresss linked to your Self Serve account, please go to https://widget.telus.tiia.ai/publicmobile/publicmobile.html and when you're there, type in "change self serve e-mail address" in the chatbot window. After a customer support agent does that for you, the regular passsword reset option on the Self Serve page can be used.
08-31-2022 04:02 PM - edited 08-31-2022 04:02 PM
you need the help of a service rep they will help with your email and update your cc if needed
There are two ways to contact a customer service agent , open a ticket through Simon here https://publicmobile.ca
Or private message them here
https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user
