have an LG TM250 flip phone CDMA is this phone compatible?
crodina
Martin
Legend
Legend
Hello,
Depending upon the apps the phone has, you can use it as an alarm clock, notepad, radio, timer, camera, calendar, etc.
That's what I'm doing with mine.
benwarez
The only thing that can CDMA devices owners can do with their phones is to keep it as souvenir, may be one day they wll show it to their Grand sons to remember them of old cell phones days that Grandpa was using
chukdefatey
Yes it's compatible on Telus's CDMA network but the network is set to be decommissioned soon
makkahn28
No. PM uses Telus's HSPA+4G Network, which is Sim Card. CDMA is ancient history
