03-04-2015 12:38 PM - edited 01-04-2022 12:34 PM
It says to tap -phone icon- on home screen and then "1" and follow prompts. However, nothing happens.
08-07-2016 02:11 PM
Thanks for that info Griff, I was having the same problem and this has resolved it!
03-13-2015 12:29 PM
03-12-2015 09:55 PM
@playohone No worries, I've met a lot of people who didn't know about the 1 for voicemail speed dial.
Glad to hear it's working for you now!
03-12-2015 09:45 PM
Thanks very kindly for both responses. I feel a little silly, but yes, holding the "1" does bring me to the voice mail setup. I was "tapping" rather than " holding".
03-04-2015 12:49 PM
03-04-2015 12:43 PM
Are you holding the #1 or just pressing it once? If you hold 1 it should auto-dial into the voicemail centre
