esim transfer
dking1966
Public application will not load so esim setup is not possible.  Not a great customer experience frankly its a joke
2 REPLIES 2
dking1966
done that multiple times clearly your app is a issue, look at your reviews
HI @dking1966
try uninstall, reboot and reinstall the PM app and re-login
if that does not work, ask support to help,
you can submit  ticket by direct message:
