error logging into community when sent a ticket by SIMon
AidenHR
I need a PUK code to activate my sim card, but every time Simon sends me the ticket to speak to a moderator I get an error code ("error logging in") despite having the correct username and password. Is there any way I can simply send a message to a human without going through the bot?
12 REPLIES 12
norkwn
I have the same problem
heather11
Tried both of those things. No luck.
 @heather11
Try another browser or clear cache/site cookies or use incognito/privacy mode.
heather11
This is the exact same issue I'm having.
I'm currently logged into the Community (or else how could I have posted this?).
However when I click the Chat link to "Submit a Ticket" for a port request, a new window opens that I'm not logged into, and it keeps saying "Error logging in", even though I'm using the right credentials. I use LastPass so it's impossible to mess this up.
Why doesn't the new window that pops up already have me logged in? This is quite odd.
@AidenHR your phone is locked to the previous provider. Contact them and ask them to unlock it for you. You will need your imei number dial *#06# to get it.  You can also contact Samsung online and ask them to unlock it for you. Stay safe.
@AidenHR wrote:
Hey there,
The message is "Invalid sim card: Network locked, sim card inserted" and yesterday it was written I needed a PUK, but my phone is a samsung so I should just need to get through to a moderator.
Yes, I am using the same username and password.
Thanks!
Yeah that means your phone's locked. Samsung can get you unlocked. I don't think the moderators will get that for you unless the phone is from Telus/Koodo.
AidenHR
Many thanks!
AidenHR
Hey there,
Thanks!
hairbag1
https://www.publicmobile.ca/en/on/get-help/articles/where-to-find-your-puk
sunflowershine
@AidenHR You can send a private message to the moderators directly by click on the "envelop" icon  next to your sign out icon. You can send to "Moderator_team" and let them know your question. They will answer within 48 hours.
What is the exact message that your phone is saying?
It might be that the phone is locked to the previous provider. If you have a Samsung you can ask them directly. Otherwise you'll need to ask the previous provider.
Are you using the username/password that you used here to log in to the community?
