11-06-2022
05:19 PM
11-06-2022
05:20 PM
computergeek541
Hi trying to set up new payment system but PM is not letting me sign into my account. They are sending the code for a password reset to my Samsung s10 but it's not arriving....
11-06-2022 05:30 PM
thanks I will try!
11-06-2022 05:24 PM
Hi @Gofiona you cannot have it to send to email?
and your phone is active?
Maybe open ticket with CS agent and have them to change your account to the proper email
at : https://publicmobile.ca/chatbot.
First type Forgot Login,
11-06-2022 05:22 PM
@Gofiona wrote:Hi trying to set up new payment system but PM is not letting me sign into my account. They are sending the code for a password reset to my Samsung s10 but it's not arriving....
Access to your e-mail account isn't need to reset your Self Serve password if you have access to that phone number's service. There is another option available to send the code by SMS text message. Have you tried that option to see if that one works?
11-06-2022 05:22 PM
@Gofiona Try using incognito/private browsing mode. Check your spam or junk folder for a reset password email. I assume your line is suspended so text option can't be used. If all fails, you will have to reach out to PM CS Agent to reset your password.
Here’s when and how to contact our Customer Support Agents:
