09-23-2021 10:49 AM - edited 01-06-2022 03:36 AM
09-23-2021 12:59 PM
you Have To Submit a Ticket To Contact Customer Support Agent by CS_Agent ,
Explain your issue to they can solve your issue, they are nice service Team the will help you 100%. and they will change for you,
Here’s how to contact Customer Support Agent by CS_Agent,
Good Luck...
09-23-2021 11:13 AM
Here’s when and how to contact our Customer Support Agents:
09-23-2021 11:10 AM
You should have welcome email from PM somewhere in your mailbox unless you delete it ...
It could be the same as one you use for Community. Go to your Community profile and you will see it there
If everything fails you will have to contact CSR to help you out.
09-23-2021 10:53 AM - edited 09-23-2021 10:54 AM
@PETERWIEBE Quickest way is to try using the Forgot Password link and try with all the possible email addresses you might have. Once you have the correct email entered, you will the be asked to answer the Security Question you set up earlier.
If you still unable to get through Forgot Password link (either because you still cannot figure out the email or cannot answer the security question), open a ticket with PM CS Agent then they will sort it out for you
1. For faster response (2-48 hours), Click on the bubble in the lower right to request CS Agent assistance, or use this direct link: https://publicmobile.ca/chatbot.
Start with typing "Submit a ticket", click "Contact Us", click "Other" from the choices, click "Click here to submit a ticket". Then follow to complete the ticket submission.
2. Or you can Send a private message to the CS Agent here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
**After the ticket is opened, monitor your Community inbox, envelope on the top right. CS Agent will communicate with you via messaging within Community
