email address
benz4
I have another phone # attached to my account.
When I try to go to the account from that Phone # It requires a email address. I cant log in with any of  3 email addresses we have. Is there a way we can find out the email address?
The phone # is:  ###-###-####
@benz4 it you cannot figure out which email address eas used and the recovery buttons didn't help, please engage support by direct message:
Andy85
Hi @benz4
When you are at the login screen, I suggest you click on "Forgot Email". Further instructions will be provided to you so that you can retrieve the details required to log in!
@benz4  You can use the forgot email option and see what emails you use gets the code sent to it . Also if your using the same device  to try and log into the different accounts be sure to clear Web browser cave a cookies and go incognito or private mode to access the next account each time
