04-01-2024 06:19 PM
I got a phone plan with eSIM but doesn’t work. I bought a physical sim. How can I switch my subscription to physical sim
04-01-2024 06:34 PM
hi @Hp3 in case you are using app, the place to change sim is slightly different. Login to the app, from the bottom, go to Account, click Change your sim card and enter the new sim card number there
04-01-2024 06:25 PM
@Hp3 You can do this in your account . Profile page and sim swap the number
SIM SWAPPING profile tabs
04-01-2024 06:23 PM
@Hp3 log in to your account / Profile / Change sim...
04-01-2024 06:22 PM
@Hp3 Login to your self-serve account and change SIM card number.
https://www.publicmobile.ca/en/bc/get-help/articles/change-sim-number
