eSIM not working
Snowypinto12
Trying to get esim installed on new phone. Going from a physical one to new esim. It says it is unable to work and to contact public mobile
9 REPLIES 9
hi @Snowypinto12
sorry, then you really need to check with PM agent.  Message them
Snowypinto12
Yes. I did. Even during the eSIM activation a phone notification said “cannot activate please contact public mobile”
hi @Snowypinto12
again, no need to update the eSIM number.
did you follow the steps above to confirm if the PM eSIM in on your new phone, set as Primary and Enabled (or Turn on this line is toggled on)?
Snowypinto12
I see the rain is there but there is no number associated that I can find
sorry @Snowypinto12 i was wrong, you don't need to enter the sim number yourself since you are using eSIM
did you buy the esim on your new phone already?  Check Settings->Cellular or Sim Manager to see if the PM esim is there.  Make sure you removed other sim card on the phone, other eSIM are disabled and only the PM eSIM is enabled.
then make sure the PM eSIM is set as Primary, then Reset Network Settings on the phone and it should work
samsunga31
@Snowypinto12 wrote:
Where would I find the number for my new eSIM?
open your phone settings, enter eSIM and it should take you directly to it. Or go to settings and About. There should show your eSIM number as well.
Snowypinto12
hi @Snowypinto12
you might not need to ask PM to help , you can do it yourself
you need to login My Account and go to Profile page to update sim card number.  If unable to receive 2FA SMS, click "Didn't Receive Code" or "Resend Code" and Select "Send Email"
But if you are unable to login My Account at all, then you will need to ask PM support agent to update the sim card number.  You can submit  ticket by direct message:
samsunga31
Check to see if the eSIM actually downloaded. If it did, then make it the primary line. And then restart your phone.
If you still need help, csa can be reached here.
