eSIM not activating
macwin
Hello, I bought eSIM and while installing, it fails to install. In process it deactivated my physical SIM. Tried to reinstall the eSIM thru my account on desktop and scanning the QR code and that is also fails. While purchasing the eSIM, it did check the eSIM compatibility and it was ok. Any chance to reactivate the physical SIM back till I can resolve the eSIM issue?
Currently I am without the mobile service.
Thanks
Brr5000k
Tried this and still didn’t work , I’m so stuck and I need my services working
@macwin
 the eSIM could have been installed and not not enabled properly.  Please check the Sim Manager or Settings >Cellular screen
Make sure the one associated with PM sim and your phone number is enabled.
(On iPhone: Settings->Cellular , make sure the PM eSIM is set as Primary on "Cellular Plan Label" and "Turn on This Line" is toggled on)
Then click Reset All Networks on your phone and it will work.  (Please note that Reset all Networks will also erase your saved Wifi and Bluetooth connections, but you just need to add them back after). Also, it is possible you have to reset it multiple times for it to work.
if it still does not work, please open ticket with PM support
Chalupa_Batman
Hello @macwin
If you are having issues with your eSIM, please contact a CS Agent via this link
Their reply will be in the top right corner.
