eSIM issues
Success1
My friend recommended lucky mobile for me. I logged into it and purchased a subscription. Unfortunately it’s not installing- multiple times we have tried.
please advise
@Success1
I'm not sure if this is related to your issue...but while trying to log in to my account, I get an Oops...Internal Error message. Could possibly be causing your drama also...dunno but try again a bit later.
Success1
While I was subscribing it said I was eligible. iPhone 13 lol
hairbag1
@Success1
so in your case, it's Unlucky Mobile huh !
Some cells aren't able to use esim...what make is your cellphone ?
hi @Success1
can you check your Settings->Cellular screen (or SimManager) and see if there is a Public Mobile sim profile there?  if it is there, turn on "Turn on this line" or enable it
slusagm
this is Public Mobile here
for esim problem, ask PM to help
Since you cannot properly login, you won't be able to open the preferred Chatbot ticket.  So, you will need to message them here:
