01-25-2026 08:45 PM
I tried with QR code which sent in activation mail and again I bought new eSIM in the app for 5$. Not able to activate. Kindly help
01-27-2026 12:13 PM
No reply from till now
01-26-2026 12:20 PM
I didn’t get any reply till now , even after 12 hours. Kindly let me know if any customer care number
01-25-2026 08:48 PM
hi @GokulPonraj
the esim not work at all?
first, it is installed there? make sure the newest one is there. And disable all the old one and the old carrier sim
the latest PM esim should be enabled, and set as Primary. Then Reboot phone and click Reset network settings and test
if still unable to get it working, ask PM support agent to help.
you can submit ticket by direct message:
01-25-2026 08:47 PM
use this link to message customer Support...
