05-22-2024
04:48 AM
05-22-2024
10:35 AM
computergeek541
I transferred my phone existing phone number from another carrier after I activated with an eSIM ; now it’s working fine but my phone and cellular number in the settings shows the eSIM number which I activated before transferrer it. Anyone with same experience please help me out to fix it.
06-01-2024 11:16 AM
@HALIMACS wrote:What worked @RencyAntony ?
Resetting network connections or updating number on iMessage?
For iPhones it's usually resetting the number that works.
05-22-2024 07:07 PM
05-22-2024 11:13 AM
Yes it worked. Thanks 😊
05-22-2024 06:26 AM
try Reset All Networks or Reset Network Settings
if you have an iPhone and you see the wrong phone number on iMessage, go to iMessage settings, remove the phone number. Reboot the phone. Then go back to iMessage settings and put the correct number back
