eSIM Card
TAWATI
How can I get QR code sent to my email?
9 REPLIES 9
Judebabe
it was just in my account area, I was trying to install on a iphone 11 and needed QR code to finish. QR code did not show on my phone, just pc.
fixin
@Judebabe - I just checked the purchase eSIM and SIM card number assigned to my second account... could not find it.
Also, my second account is on an eSIM. Only shows up within the activation email.
Better to just contact CS_Agent @TAWATI:
⬇️ Click the link for an Agent * ⬇️
If the link above doesn’t work, please go here to create a ticket to CS_Agent: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
* - CS_Agent will typically get back to you within 48 hours. They work 7 days a week from 9 AM to 10 PM EST.  You will be required to login to your Public Mobile Community Account to contact CS_Agent. Once you are finished making the ticket with CS_Agent, please ensure that you monitor for an agent because they may notify you asking for some information via Private Message, in your mailbox by clicking this link here: Messages
HI @Judebabe
which page on My Account you see the esim?
Judebabe
sign in to PM account on a pc....not tab or phone. You can find your QR code
@TAWATI were you using the PM app to subscribe to get to Step 6 the final step?
If you did,  there is a chance that the error was there because the Public Mobile esim is already installed and just not properly enabled
On Android:  Check your Sim Card Manager and see if a Public Mobile eSim is there.  If so, make sure it is enabled.
On iPhone: check Settings > Celluar and see if the eSIM is there.  If it is, make sure the PM eSIM is set as Primary on "Cellular Plan Label" and "Turn on This Line" is toggled on
And if the Public Mobile eSIM is there, disable or delete those non PM sim (eSIM/Physical sim).
If the non-PM sim is physical, remove it.  If the non-PM sim is an esim, disable using the SIM Manager on the phone (or set as Secondary and turn off "Turn on this line" for this non-PM esim)
Then reboot the phone and click Reset All Networks on your phone and it will work.  (Please note that Reset all Networks will also erase your saved Wifi and Bluetooth connections, but you just need to add them back after). Also, it is possible you have to reset it multiple times for it to work.
if it still does not work, open ticket with PM support using Chatbot:
1. Open ticket via Chatbot (need access to My Account): At https://widget.telus.tiia.ai/publicmobile/publicmobile.html
    Start by typing "Submit a ticket", then click "Contact Us", then "Other", then "Login" and finally click "Click here to submit a ticket ↗"
@TAWATI
If you are a new customer and don't have eSIM installed and also did not get QR code via email, then you will need to contact customer service agent for further help. Either submit a ticket via the chat bot or via the following link:
TAWATI
I can not  manage to purchase the eSIM yet
TAWATI
I have not received any QR code yet
fixin
@TAWATI - Did you just activate your PM service?
The QR code for activating eSIM should be in your inbox
Welcome to Public Mobile  copy-images-1.jpgWelcome to Public Mobile  copy-images-2.jpgWelcome to Public Mobile  copy-images-3.jpg
The email should look like this (X = personal information like QR codes, account numbers, names, phone numbers, and refer-a-friend code)
