10-21-2025
11:24 AM
10-22-2025
12:11 AM
computergeek541
Hello,
I would like to transfer e-SIM to Physical SIM. Pl. help me.
Thanks
edited by computergeek541: changed category labels as this discussion isn't related to Community
10-22-2025 03:30 PM
@CSA_PM wrote:Hi there,
To transfer your service from an eSIM to a physical SIM, you’ll first need to purchase a physical SIM card from a nearby store or from Amazon.
Once you purchase a physical SIM card, you can activate it directly in your online account under the “Activate a new SIM card” section.
The above isn't correct. Doing so will cause the customer to accidently open a second Public Mobile account.
The customer needs to use the Change SIM Card feature.
10-22-2025 08:38 AM
Hi there,
10-21-2025 11:29 AM
hi @RP25
you got the physical sim card yet? buy a new Public Mobile sim card from Telus, Koodo, Mobile Klink store, then login My Account to update the sim card nmber from Profile page
if you cannot login My Account, ask PM support agent to help
You won't be able to submit Chatbot ticket if you cannot login, but you can still submit ticket by direct message:
10-21-2025 11:28 AM
buy a Public Mobile sim, log in to your Public Mobile account (using the app) > Account tab...scroll down to find Change Your Sim Card. There you can update the sim number to the number on your new hard sim.
Log in to Public Mobile to buy a hard sim but that could take 3 weeks or more for delivery. If there's a Mobile Klinik in your area...they usually have the PM sims for sale.
