08-23-2025
04:20 PM
08-23-2025
04:47 PM
computergeek541
i put the second sim into the phone and it was not seen.. i went to the settings and looked thru sim options.. i am now puk locked and neither sims are visible on the phone. help
08-23-2025 04:41 PM
look like you couple have locked your sim. Ask PM to help for a sim PUK code to unlock
Just open ticket with PM using the Orange Chatbot icon on the lower right. (For 2FA when login, you might need to use email to receive if you cannot receive the text on the phone.) Type the question Submit ticket and select Contact Us to get to ticket open screen
But if you have trouble using Chatbot to open ticket, then message PM using this link:
08-23-2025 04:38 PM
Contact a CS Agent for a PUK unlock code and see if that helps.
The Public Mobile chatbot is currently unable to create trackable tickets for members who are unable to log in. So for this reason, please use the following link to contact customer service.
08-23-2025 04:27 PM
it is a phone3 issue. in the sim settings, there is a "pin lock" setting i looked in there and now my phone says it is PUK locked.. personal unlock code.. locked. i thot the sim pin was what you used to open the phone.. so i put it in and it refused it and locked me out.. no service but emergency. i reset to factory and trued to set up the phone again from scratch and am now locked out of it real good.
08-23-2025 04:23 PM
hi @puiblics4m
it could be a phone issue. does the PM sim card work on another phone?
and what the PUK error? could be about carrier lock and not sim card lock
