4 weeks ago
I need to downgrade my plan temporarily due to my finances why is there no option to
4 weeks ago
hi @Kathyc1
downgrade is possible but it can be hard
what plan you have now? if you have a plan over $30, there might be some $30 or $35 choices
but if you are at $30 , likely not much choices and you might need to check often for any offer
4 weeks ago - last edited 4 weeks ago
@Kathyc1 wrote:I need to downgrade my plan temporarily due to my finances why is there no option to
Hey @Kathyc1
Public Mobile sadly doesn't allow downgrading which is unusual since it's a prepaid service. I would suggest that you contact customer service and advise them that due to your financial situation, you're unable to keep the current plan and ask for some understanding. If they are unable to assist you, the only option is to port out to another service provider who will offer you a plan you can afford.
If you are able to log in, please use this link to the Public Mobile Chat Bot which will direct you to creating a trackable ticket. Enter CONTACT US into the chat and follow the prompts.
If you’re unable to log in to your account, please use this direct link to reach out to a CS Agent.
