yesterday
yesterday
HI @FireFly11
so, the system charged you twice? or you manually submitted another payment after the system charged you? Did you check the payment history and see both charges? If the system charged you twice on the same account, you should see a credit on August and the credit would have been used on your renewal on Sept 19.
or if you don't see the two charges on payment history but see it on your credit card, ask PM support agent to check and confirm. please submit a ticket with CS Agent using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
yesterday
Hello @FireFly11
There have been several complaints made of double charges for the month of August. Please create a ticket to have this investigated. They will give you an option for refund or a credit to your account.
To submit a ticket with CS Agent using this Chatbot link
Type Customer Service and follow the prompts. If you are having any issues, here is a direct link by sending a private message
yesterday
we are just customers like you here. But if you want this to look into and got refunded, PM can help
Just open ticket with PM using the Orange Chatbot icon on the lower right. Type the question Submit ticket and select Contact Us to get to ticket open screen
or message them using this link:
