4 hours ago
Double charge on my auto payment . what should I do . Thanks
2 hours ago
Thank you .
4 hours ago
are you sure that you have been double charged? Check both your credit card/ payment statements and payment history on the public mobile app or website?
akso are you sure that you have not changed your plan recently?
If you are sure that you are double charged, submit a ticket with CS Agent using this Chatbot link
Type Customer Service and follow the prompts. If you are having any issues, here is a direct link by sending a private message
4 hours ago
@DuckyP have you received your September statement showing two charges in August?
And there should onky be one?
You can open a ticket through the chatbot for Public mobile to review.
