05-05-2019 12:34 PM - edited 01-05-2022 04:46 AM
Hi,
my phone got deactivated .it is all paid, I just did not use it for 2 months.
when I deal *611 customer service it says to reactivate I need to top up. but there is 0 $ to top us as it's paid.
how do I reactivate it then?
Thank you
05-05-2019 11:43 PM
@mansi wrote:Hi,
Thank you
If the lost/stolen trick doesn't work, try paying another $1. If it says plan is active, restart phone. If none works, time to contact mods. https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
05-05-2019 04:55 PM
What does self serve overview say?
Try the lost stolen trick via selfserve.
05-05-2019 12:40 PM
@mansi wrote:Hi,
Thank you
@mansi Are you on a 90 day or 30 day plan? Are you on AutoPay?
05-05-2019 12:36 PM
@mansi wrote:Hi,
Thank you
Are you able to log in to your self-serve?
If so, maybe you could post a screen snip of your overview page. Blank out personal info of course.
