10-15-2019 12:15 PM - edited 01-05-2022 07:34 AM
if you use ur data up how does tht work after? do they charge per use? or does ur data just stop working till next month is paid? thanks
10-15-2019 01:07 PM
@laceydawn81 After running out of data, the other option would be to peform and immediate plan change to a different price plan. However, you would lose the original plan payment.
10-15-2019 12:24 PM
@GR thanks for the info. im a newbie just been with them a month so wasnt sure 🙂
10-15-2019 12:22 PM
@laceydawn81 it just stops! You can either buy a data add on to get more or renew your plan early or just wait until your next month to get your data back
