12-05-2023 10:26 AM
12-05-2023 10:36 AM
if you picked the wrong data add-on they might give you the correct one OR they might just credit your account and cancel the add-on.
12-05-2023 10:28 AM - edited 12-05-2023 10:29 AM
@LarAhm you can’t , but If you picked the wrong add on by accident you can use this direct link to support to see if they can reverse it for you
send a private message To CS_Agents
⬇️⬇️⬇️⬇️⬇️Link below ⬇️⬇️⬇️⬇️⬇️
