08-05-2022 01:03 PM
Hi,
I am being informed that I am using up all my data early, which never happened before. Most data usage is being registered btw 12midnight- 1am when I am normally asleep. What is going on? And what can I do to fix this?
08-05-2022 05:21 PM
@esjliv wrote:You cannot see the Data usage @Yummy ? Me Neither, in that Snapshot screen!!
But, what I did notice, if you download the information you will see all usage (including data) listed.
Kinda of a pain, that you cannot see it in the Snapshot screen though. 😒
Thanks for the tip. Yes, I can see data usage after downloading it. No comments... 🙄🤐
08-05-2022 04:30 PM
@SHelleman wrote:Hi,
@SHelleman what is informing you? Is it a text by Public Mobile or is your phone set up to warn you when it reaches certain data limits, and perhaps cuts off or stops a certain point?
Check your settings for this, if this is the case.
Most accurate of what you have remaining should be listed here, so go by this.
If the texts/messages you are receiving does not match above, I would safely ignore those texts.
Now, as for data being used while you sleep. There is a small buffer amount, about 5mb that can show daily, but gets returned to you. If you toggle into/out of airplane mode does it reset your data in My Account?
If there is more unknow used data, ensure you check all the data settings on your device and all apps. Best to have data off when not in use anyhow to accidently burn up data. Weak wifi signals can do this if your data is on.
If you are really seeing large unknows ask CSA, but it is likely on a device issue, I'd say.
Methods to submit tickets to Public Mobile Customer Support Agents (CSA) found here:
https://www.publicmobile.ca/en/ns/get-help/articles/contact-an-agent
08-05-2022 04:30 PM
08-05-2022 04:23 PM
@Yummy wrote:PM is supposedly to use minuscule data every day but that is returned to you every day.
Strangely I cannot see my data usage day by day even though system says I used 13MB in this billing cycle.
Before PM redesign it was possible to see daily small data usage amounts. Very strange???!?!?
Why I cannot see when these 13.55MB have been used???
08-05-2022 03:08 PM
call *611 and press option 3 and you ned your 4 digit PIN and check it out.
if not post in your account contact to support team by CS_Agent
check out your device turn off background apps.
08-05-2022 02:11 PM
Yeah this new interface has a bunch of bugs. I can't see mine either and randomly one time I sign in it says I have used about 80% of my data and other times it says 40% (which is the true amount) Hopefully they fix all these bugs.
08-05-2022 01:57 PM - edited 08-05-2022 01:58 PM
