08-04-2022 11:10 PM
I activate Two accounts and one of the accounts never worked after responding to the text message with a yes.
08-05-2022 05:07 PM
@Julibar wrote:I activate Two accounts and one of the accounts never worked after responding to the text message with a yes.
Do you mean the My Accounts did not work on 1 phone, or the service on the phone itself didn't work @Julibar
If you activated these 2 accounts online log into both My Accounts and ensure they are showing Active status.
If you cannot log into the second My Account, but got charged for it ask CSA about this activation.
Methods to submit tickets to Public Mobile Customer Support Agents (CSA) found here:
https://www.publicmobile.ca/en/ns/get-help/articles/contact-an-agent
If 1 of the phones do not work, try:
08-04-2022 11:31 PM
@Julibar I assume your first account was working perfectly and just not the second account
on the second account, can you at least make outgoing calls?
on the second account, did you request porting? If so, you replied YES? If you did reply YES, can you put in your old sim card back to a phone and see if it can make calls and receive calls? If you can still make calls and receive calls on the old sim card from the old provider, the porting was not completed yet, the old provider has not release the line yet
If your old sim card no longer working, then put your PM sim card back in and reboot the phone once again and try incoming calls once again and see if it works. Let us know the result
08-04-2022 11:17 PM - edited 08-04-2022 11:20 PM
