05-26-2022 01:57 AM
i payed my bill and by the time my plan reactivated it said my data was all used, i have everything shut off so no data gets used, ive rechecked settings several times and everything is off still the only cellular data permission i have is for public mobile to allow me to add payments, id like to be reimbursed for the data, i know you can under your customer retention protocals
05-26-2022 02:23 AM
@Rryan1988 What plan do you have?
If you login to My Account, is it showing your Account status is Active? or any chance it is still showing Suspended or Plan Expired?
If account status is Active, do you see a line about data like this in the Overview page?
If you check Usage log ( https://selfserve.publicmobile.ca/Overview/viewUsageChangePlan/ ), do you see if it shows any data there from the date you activate? If it shows that you used data, does the data usage make sense?
If your account is now active, you don't see a line about data and your Usage page showing no data used, open a ticket with PM Support to get it sorted out:
1. If you have access to My account: At https://publicmobile.ca/chatbot.
2. If you don't have access to My Account or have trouble with Chatbot: Private message CS Agent at:
05-26-2022 02:55 AM
it shows/ or did of course theyre doing maintence now
05-26-2022 03:05 AM
05-26-2022 03:12 AM
yes, my phones flashed, no gapps, just a basic gsm/lte basic, im suprised it even was able to use that much cause i have it set for the lower gsm freqeuncy
05-26-2022 03:32 AM
i figured out what the issue was for me, the public mobile site continued to refreshes in the back ground because i didnt fully log out😔
05-26-2022 05:59 AM
Keepmin mind you can use more data on the 3G network vs the 4G LTE network depending on use as 3G data is unthrottled whereas the 4G LTE data is throttled to 3mbps.
To contact customer support : Submit a support ticket via SIMon the chat bot Click here
Or if you cannot submit a ticket via SIMon then Click here ....for additional member supplied info.
05-26-2022 06:20 AM
You mean use data at a higher rate, right @darlicious ? (3G vs 4G/LTE)
05-26-2022 11:07 AM
Sorry to hear that the data can go so quick on the 15 plan. Are you under the old rewards plan or the new one bc you could get a 1GB add on with only 10 points to hold you over on times you need the extra data
05-26-2022 11:09 AM
@Rryan1988 wrote:i figured out what the issue was for me, the public mobile site continued to refreshes in the back ground because i didnt fully log out😔
@Rryan1988 Oh no, that's not good.
