11-13-2020 07:23 AM - edited 01-05-2022 04:06 PM
bought data and it was not out on my account to use
11-13-2020 07:46 AM
Check and make sure you have the APN settings.
APN: sp.mb.com
Proxy: Leave blank
Port: Leave blank
Username: Leave blank
Password: Leave blank
Server: Leave blank
MMSC proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
APN protocol: IPv4
APN roaming protocol: IPv4
Bearer: Unspecified
MVNO type: GID
MVNO value: 4D4F
11-13-2020 07:31 AM
@tamaraxo12 Did you use data before? If this is your first time, you might have change your APN settings.
11-13-2020 07:30 AM - edited 11-13-2020 07:30 AM
@tamaraxo12 reboot your phone if data now shows under my data & add-ons
11-13-2020 07:29 AM
it shows i have 200 of data but its not working
11-13-2020 07:27 AM
@tamaraxo12 Doing the steps doesn't buy the add-on if the funds aren't there yet. It only adds funds. I know that doesn't make sense but that's the way it is. Do the process again to buy it.
11-13-2020 07:25 AM
i added the funds and bought the add on and it went thru from my bank but didnt get added on to my account
11-13-2020 07:25 AM
If the money is still in available funds, go back and purchase the add-on now. It doesn't let you buy an add-on if the funds aren't there.yet.
11-13-2020 07:24 AM
Two steps to buy an add-on.
1 add money to account
2 buy the add-on
Is the money for your add-on possibly in your available balance? If so now go buy the add-on.
