data add on
kimraette
Hi there,
I am totally new to all of this so please forgive me but I purchased the $30 data add on and it does not seem like my account received the additional data?  Am I missing something?  thank you!
10 REPLIES 10
Add-ons are prepaid so no guarantee of a refund.  It will remain in your account until it is used up.    If you want to contact a moderator.
Moderator can be reached at
Purchasing add ons is a two step process.  You to have to add and purchase it.
https://www.publicmobile.ca/en/bc/get-help/articles/purchase-add-ons-through-self-serve
mookm
I bought 1 gig before my data ran out and it never worked,  how do I
get a refund for my 30 bucks?
@kselmak wrote:
Hi @geopublic
Sorry that was just an example from one of my accounts so that op understands what i mean
If 1g is not there than it's either used up or the purchase didn't go through
And if it didn't go through them they should still have extra balence on the account and can attempt the purchase again.
If balance is 0 and they are sure they didn't use it, maybe something wet wrong and mod help would be needed
@kselmak  Noted, Thanks!
Hi @geopublic
@kimraette  From that screenshot it appears that you only added the funds to you account but you still need to go into self selfserve and make the purchase. As @ShawnC13  mentioned, it's a two step process.
kselmak
Hi @kimraette
When did you purchase add-on?
What plan are you on?
Can you login to your self-service and take a screenshot of the overview page, in particular the add-on section ( please blackout any personal info)
Thanks
goldilock
If you log into your account, and click :"my plan and add ons" does it show 30GB?
ShawnC13
@kimraette wrote:
Hi there,
Purchasing an add-on is a two-step process the money is probably sitting in your available funds and you will just need to re-purchase it.
Purchasing addons is a two-step process.  Here is a great tutorial on how to purchase addons created by @srlawren  https://productioncommunity.publicmobile.ca/t5/Plans-Add-Ons/HOWTO-Purchasing-Add-ons/m-p/198974
geopublic
@kimraette wrote:
Hi there,
@kimraette  Do you have an active plan associated with your account or are you just looking for data?
