confirmation of data
Peer
I just switched from Freedom Mobile to Public Mobile with $40 plan with 4Gb of data per month. How can i chech that i have got 12 GB of data for 90 day pla.
MoreYummy
After successful activation, in your self serve portal, you can see your plan with the correct features after 72 hours or so.  If not then shoot a message to one of the MOD to fix it, expect delay during these days when promotion is going on.
Do not freak out if after 72 hours they still didnt show up. Give it a week or even 10 days then it will show up. But it should show up way earlier then this, if it doesnt let us know here
Samianauman
It's take upto 72 hours to get bonus 6gb I would suggust check back your self serve after 72 hours since you activated your sim. Mean while if you login to your public mobile self serve verify your plan. Right now its suppose to show as
6gb data
Province wide
Global text
120 dollars 90 days plan
That's the one you suppose to have and after 72 hours or so you will notice a difference instead of 6gb its will change to 12 gb
Thanks.
** I am not a Mod, please do not include any private info in a private message to me.**
