09-22-2024 10:07 AM
if I change my subscription before the renewal date in October, will I be reimbursed the pro-rated difference?
09-22-2024 01:47 PM
thank you for your answer! 🙂
09-22-2024 10:33 AM
no reimbursement for early plan change before end of the current cycle
So, it is better to use Change on Renewal for plan change. But if you already used up all the data, then yes, you might want to use Change Now option. And if that is the case, you already used up data, so you didn't lose much even without reimbursement
09-22-2024 10:11 AM
Good Morning @alexBozheva
No, you will lose it. This is pre paid service meaning you pre pay for what you want. This is why it is always best to do it on RENEWAL date. Unless there is an urgent need for data or something and you see the value in changing and don't mind losing whatever you already paid to get that data.
09-22-2024 10:10 AM
@alexBozheva No you will not. Better to select change at next renewal.
