changing plans
doberman
I had a 90 day plan.
It has expired.
I am trying to change to a 30 day plan.
I have 70 dollars of credit.
How do I do this.  It does not let me change plans.
srlawren
@will13am I think you're confusing the "Expired".  In this case, I believe @doberman means suspended, meaning as @xCameron94x points out, means you cannot change the plan thorugh self-serve but need to contact the moderator team for assistance.
EDIT: @doberman please use this link to send the moderator team a private message with your phone number and the details of the plan selection and they can assist you.
will13am
@doberman, are you sure you want to switch plans?  Even though a plan you have may be expired, you can still renew the plan because it is grandfathered.
xCameron94x
the mods will need to do that for you. You need to send them a private message
