3 weeks ago
- last edited
3 weeks ago
computergeek541
I have an existing plan but I like to change my subscription to a lower priced plan.When I click on change plan it gives me only two higher subsriptions.
Do I need to cancel this plan and start over again to get the lowered price rplan?
3 weeks ago
what plan you have now?
All subscribers can only change to plan offered on your My Account, no exception.
It is true that you won't see too many choices to downgrade, but it is not impossible. Different plans will be offered weekly or monthly, so check back often
