change of bonus data
asharaby
I just signed up yesterday and got he bonus 5GB for 12 month but the sign up bonus data jus went up today to 12GB.
Do you think I can get the new data bonus instead of the 5GB?
@asharaby wrote:
I did the private message solution, really hoping they'd add it for me.
the plan is the 3GB for $35 with the $5.25 credit every month.
finger crossed now
For future, please open all tickets using the chatbot whenever possible.  Using the chatbot isn't really optional and it's not meant to be the customer's chocie of chatboat or private messaging.  Sending a private message results in receiving slower service.
asharaby
finger crossed now
Outdoorsman
@asharaby
Hi contact a service rep and explain your situation hopefully they can help change it for you
There are two ways to contact a customer service agent , open a ticket through Simon here https://publicmobile.ca
Or  private message them here
@asharaby   which plan are you on?
the $40- 15GB is a good deal without the new of the code.    The 12GB bonus is only for 12 months anyway
But if you like, you can open ticket with PM Support.  If it is an honest mistake and you missed the code, they usually able to add it back for you.
Please open ticket with Chatbot
1. Please open ticket via Chatbot (need access to My Account): At https://publicmobile.ca/chatbot.
