change credit card
10-13-2023 05:05 PM
How do i change my credit card information
I keeping getting error message and to try agian for two days now
Payment
10-13-2023 05:24 PM
Try using a different internet browser.
10-13-2023 05:19 PM
You can only do 2 attempts per hour before it locks you out. Wait an hour and try it again. But it might also be that the card entry screen has been locked anyway. You would need support to release that for you. Are you sure the postal code matches the billing address postal code?
