04-06-2019 05:25 PM - edited 01-05-2022 04:12 AM
after finally getting my phone problems fixed, I found that I canphone and recieve calls, recieve texts but cant send texts. I have set up access point names as required and have referred to the community comments regarding my problem. The suggestion was to input the 164..... number into the Message Centre spot but mine is greyed out and will not accept input.
04-06-2019 08:39 PM - edited 04-06-2019 08:40 PM
@bob2 wrote:after finally getting my phone problems fixed, I found that I canphone and recieve calls, recieve texts but cant send texts. I have set up access point names as required and have referred to the community comments regarding my problem. The suggestion was to input the 164..... number into the Message Centre spot but mine is greyed out and will not accept input.
Are you a brand new customer, and did you use this phone at a different carrier before? If the answer to that question is "yes", and you're using an Android-based device, you might need to delete the an existing message thread to be able to send messages to that person. Please note that by doing this, you wil lose any information in that message thread, so copy down any info that you may need to keep.
04-06-2019 08:35 PM
Please answer the questions of the above users and give more details so we can try to help
04-06-2019 06:29 PM
Could definitely use more details like what kind of phone you're using.
04-06-2019 06:18 PM
Hi, You can not send normal SMS texts to anyone? Or is it you can not send MMS (picture) texts? Which app do you use to text?
04-06-2019 05:34 PM - edited 04-06-2019 05:34 PM
@bob2 What kind of phone do you have? Be as specific as you can.
