10-31-2019 05:21 PM - edited 01-05-2022 09:37 AM
I bought 2 vouchers today a $40.00 one and a $10.00 one i added the $40.00 one fine then when i tried adding the $10.00 one it keeps telling me that it is invailed then ends the phone call need my phone to work!!!!!!!!!!!!!!!!!!!!
11-02-2019 11:49 PM
@CS_Agent wrote:Hello @taylormorris458 ,
Submit a ticket using SIMon on our website regarding your issue and someone will help you as soon as possible!
Thanks for understanding,
Kindly Regards, Daniel-Moderator's Team
Perhaps if the @CS_Agent team can help, we should look at a more direct solution than creating a ticket that is expected to take 48 hrs to resolve. Simon is great, but if you're going to initiate service, it should be more personal and direct!
11-02-2019 11:40 PM
If this is still an issue for you or if it happens again just email a moderator a picture of your voucher. They can add it on manually for you.
10-31-2019 05:39 PM
10-31-2019 05:37 PM
Before contacting moderators try to add it from your selfserve
10-31-2019 05:37 PM
So the $40 worked fine dialing 611 and the $10 one did not?
I assume they were from the same vendor and you used the similar 12 digit number from each voucher, is this correct?
10-31-2019 05:34 PM
Can you contact the moderators and also give them the screenshot of your 10 Voucher
