05-26-2020 06:36 PM - edited 01-05-2022 10:55 AM
Hi,
I've been having issues getting a one-time code to use to add a new interac contact.
What's strange is that i've had the call/sms come through on this a few months ago. I have a 672 number and I have read that this is a new area code and that it might not work, but it has done so a few times without issue in the past and now it's suddenly stopped? I've tried for 4 hours constantly. Also removed my sim, changed my network settings, reset and updated my phone. nothing! is this a problem with public? should i move to rogers or one of the more established telecoms? many thanks
06-11-2020 01:51 PM
@aalmahdi wrote:Hello, it has been now one week since I activated my Public Mobile number and still I don't receive verification code from my Bank.
Thank you
@aalmahdi The only thing I can suggest it try to change the number at CIBC to your spouses number or a family member and then back to your PM number to see if that resets it.
06-11-2020 01:36 PM
Thank you
@aalmahdi I think the issue might be with CIBC as their verification texts/alerts can suddenly stop. You might need to ask CIBC why you're not receiving their texts/alerts, or you might need to refresh the alert settings in your CIBC account.
06-11-2020 12:57 PM
Thank you
06-05-2020 01:38 AM
@aalmahdi Did you just port in you number? If yes, some banks have security measures in place to protect against simjacking so they will not send out a text for 48 hours if a number has been ported out.
Wait for 48 hours to see if that is that is the case.
06-05-2020 01:03 AM
@aalmahdi what type of phone do you have?
06-05-2020 12:39 AM
@aalmahdi wrote:I am having the same issue!! what should I do ??
#important #Urgent
Does CIBC allow the code to be sent to you using any other method? Being a TD customer, I can select either text message or phone call. I know that's not a permanent fix, but at least you'd be able to get into your bank account.
06-05-2020 12:38 AM
@aalmahdi You can contact CIBC and see if they can send a second factor verification email instead of a text. Text second factor is not all that secure anyway. If some steals your Crdentials and SIM jacks you youll be in trouble.
06-05-2020 12:35 AM
#important #Urgent
05-26-2020 07:46 PM
@Rawaz Check your usage history if the text is coming in then your device is blocking it. 😭
05-26-2020 07:05 PM
thanks for the suggestion, i tried it now however when i try adding it as a number on my account, cibc asks me to verify it with a one-time code 🤣😂
05-26-2020 07:02 PM
that's what has got me all confused! I've been on the phone with CIBC for an hour, they're now escalating it to their tech department and putting a note down in case similar calls spring up
05-26-2020 07:01 PM
thank you, but unfortunately im too invested deep with this number across many platforms and contacts
05-26-2020 06:50 PM - edited 05-26-2020 06:51 PM
@Rawaz If has worked in the past then there isn't a reason why it shouldn't work now.
Make sure you are not blocking any numbers and also check with your bank to make sure you have supplied the correct number.
05-26-2020 06:48 PM
You could setup a Textnow account and see if you can receive a sms through it.
05-26-2020 06:47 PM
@Rawaz I had problems with 672 code. Change the number to the one with old code like 236 or 604, and no more problems.
05-26-2020 06:39 PM - edited 05-26-2020 06:39 PM
@Rawaz you can try changing your number to a more common area code, if you aren't too worried about keeping your current number.
you can do this in your self serve account.
