3 hours ago
I have public for couple of weeks now. Cannot receive calls from two telus numbers. any thoughts. thank you.
3 hours ago
HI @vaso
can you receive other inbound calls outside of the 2 Telus numbers?
and those 2 Telus numbers, do you see them on your Usage history on My Account?
If you are certain it was a problem with the 2 numbers only, ask PM to check. Since they are Telus number, PM can easily escalate with Telus technicians
Please submit a ticket with CS Agent using Chatbot here:
Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
3 hours ago
did you port in your number? is the port completed?
3 hours ago
@vaso wrote:I have public for couple of weeks now. Cannot receive calls from two telus numbers. any thoughts. thank you.
Perhaps it may be something in your settings. I know that with the last few recent updates on IOS it's caused numbers to be blocked. Check your phone blocked numbers and turn off unknown callers and that may help.
