cancel subscription change
Peteski1
Hi.  I'm trying to cancel my upcoming subscription, but I get an error after clicking cancel subscription change.  I have cleared cache, tried using incognito mode, and used a different computer and cellphone.  Is there something else I can try, or maybe get someone with more knowledge to help me out?  Thank you.
1 REPLY 1
hi @Peteski1
when the subscription change going to happen? tomorrow?
did you try using PM app?
if you tried everything, you will need to ask PM agent to help.  But if it is tomorrow, it might not have enough time
 submit a ticket with CS Agent using Chatbot here:
             Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
             (If unable to receive 2FA SMS, click "Didn't Receive Code" or "Resend Code" and Select "Send Email")
If any issue with ticket submission, you can submit  ticket by direct message:
