4 hours ago
I purchased a Canada / US unlimited minutes plan with 20 gb data. The data is not working in kona hawaii, what should I do to get the data working.
3 hours ago
Here is some more troubleshooting advice on US roaming:
https://www.publicmobile.ca/en/ab/get-help/articles/us-roaming-troubleshooting
4 hours ago
Hello @sofie1
Go into your network settings on your phone. If it is set to Automatic, turn that off and click on T-Mobile. Also, make sure your data roaming is turned on. Then, reboot the phone. If that works, great! If not, then go back into your settings and try AT&T and reboot. Then Verizon is apparently a new partner but I feel T-Mobile should do just fine.
4 hours ago
hi @sofie1 someone tried in Hawaii and worked, just not sure if Kona works
but which network you are using now? First , change network mode to 4G LTE, then Manual. connect to all 3 networks T-Mobile, AT&T , Verizon, and see which one works
