04-04-2022 04:33 PM
04-04-2022 05:53 PM
04-04-2022 04:44 PM
That grandfathered plan (with US roaming) was $60 and OP mentions $50 plan? Unless OP mistyped..
04-04-2022 04:43 PM
With the uncertainty about the 3G issues in the US and the hit and miss it seems PM customers are having you may want to look into alternatives just in case if it is imperative you have data in the US
04-04-2022 04:40 PM
There used to be a plan offered that had US data included, so are you talking about a current plan or an older plan
04-04-2022 04:39 PM
Nope. All current PM plans are for calling within Canada and From Canada to US ($50+ Plans).
To use PM SIM in US you have to buy appropriate US add-on (valid for 10 days).
04-04-2022 04:37 PM - edited 04-04-2022 04:39 PM
@yumu Sorry, that data is only for use within Canada and calling to the US is free when calling from Canada. For US travel you need to purchase one of the US roaming package by choosing Purchase Add-ons under My Data/Add-ons on the overview page. Reminder to first add funds to your account and then go back to purchase the add-on.
Edit: BTW, the roaming packages are available for 10 days only and activated immediately after purchasing, so make sure to buy them as close to your trip as possible.
04-04-2022 04:36 PM
@yumu Sorry . No
No current plan include roaming data or voice or text
You will need to buy roaming add-on to use your service in US
