can't transfer my number
Bvpc
and can't submit ticket, the button is always grey, can someone help??
Bvpc
I will try, thank you!
hi @Bvpc
It could be an incomplete port.  PM porting support team can help.  I have sent you the porting support team number.  Please check your Community inbox (https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage), check for the number and call.
And in case the poring team cannot help and ask you to submit ticket (or you rather submit ticket anyway),  you can submit  ticket by direct message:
slusagm
Since you cannot properly login, you won't be able to open the preferred Chatbot ticket.  So, you will need to message them here:
