eSIM not activated
Parinda
I transferred from Roger’s and it has been more than 5hrs the transfer didn’t work. I replied YES. To the message for activation. I also tried with the QR code it didn’t work. Please look into this asap.
BW99
Hello, I am also with rogers, ported in last night around 8pm. Still not working properly. Cannot receive calls or texts. Not sure how long I need to wait more. I raised a ticket 5 hours ago, no reply
slusagm
you should be able to at least at the eSIM working for making calls
removed the old sim card or disable old esim
Check if PM esim is enabled and set as Primary.  Reboot phone and Reset network settigns
if you need PM to help, open ticket.  Since you cannot properly login, you won't be able to open the preferred Chatbot ticket.  So, you will need to message them here:
HI @Parinda
should be just a bit of delay as announced:
https://productioncommunity.publicmobile.ca/t5/Announcements/Support-Updates-50-Flash-Sale-Promotion...
But if you need an update,  PM porting support team can help.  I have sent you the porting support team number.  Please check your Community inbox (https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage), check for the number and call.
And in case the poring team cannot help and ask you to submit ticket (or you rather submit ticket anyway),  you can submit  ticket by direct message:
