05-13-2023 05:11 PM
Hi
I need to change the credit card on an account - it was canceled. We can't find the email login for the phone number that needs updating and the phone will not currently work - waiting for us to update the payment method.
How do we find the account information to pay for the service?
thank you,
Liz
Payment
05-13-2023 09:19 PM
When you activated your SIM and created this Community account with the same email on August 11, 2020. Just click on your avatar on the top right then go to My Setting…your email will show there.
05-13-2023 07:14 PM
Will do - thanks
05-13-2023 06:08 PM
hi @Liz04 please submit ticket then
05-13-2023 05:59 PM
Thanks - have tried all emails - will try submitting a ticket
05-13-2023 05:58 PM
Thanks - we've tried all of our email addresses - no luck.
05-13-2023 05:28 PM
Hi @Liz04 did you try using the Reset Password and try your email addresses?
or submit a ticket for support to help
at : https://publicmobile.ca/chatbot.
First type Forgot Login,
05-13-2023 05:16 PM - edited 05-13-2023 05:16 PM
if you don’t remember the email address, try the most commonly used emails it could be with the forgot password function. (how many could there be???)
The one that sends a password reset link is the correct email you used here.
