06-21-2017 08:05 PM - edited 01-05-2022 02:14 AM
Same problem as this:
There is currently a bug related to new activation of SIM card on your website that prevent any new customer to register.
The problem was raised by many people in the community since last fall.
The issue is at the step 2: Phone number.
The drop-down menu is empty (no choice available) and as it is a required field, it is not possible to go on from there.
The issue was present for me in French and English on the following browsers:
- Chrome Version 52.0.2743.116
- Chrome mobile version on android
- Microsoft Edge
- Internet Explorer 11
06-26-2017 03:47 PM
i bought a sim card from you guys because i had to now it is asking for a unlock # is this normal i was told this would work with this phone
chris
06-22-2017 11:10 AM
yeah, hoping that it gets sorted out fast. i wanted to get the promo offer, hence the rush. if it doesn't work out, i'll just throw away the sim card and try to negotiate a better deal with my existing provider.
06-21-2017 09:19 PM
@roniebanerjee Well then you've done all you can do. Afraid the moderators have left for the evening. Good luck with it tomorrow.
06-21-2017 08:45 PM
yes, i mailed the moderator community using the little "envelope" icon.
06-21-2017 08:43 PM
1. i have a cookie killer installed; so no cookie cleaning rqd.
2. that didn't help.
3. neither did that, assuming an android tablet is acceptable alternative to ipad
06-21-2017 08:43 PM
Sorry for the confusion. I meant did you use the facility described here: https://productioncommunity.publicmobile.ca/t5/Getting-Started/Private-Messages-viewing-and-creating....
It's preferred to the contact method found here: https://publicmobile.ca/en/on/get-help
06-21-2017 08:34 PM
i am not sure what the difference is. an email is usually a private message. if you mean an open comment, then no, i didn't post my data on the open forum.
06-21-2017 08:30 PM - edited 06-21-2017 08:36 PM
I trust you meant a private message NOT an email to the moderators?
It's a little extreme hoping this bug will be sorted shortly; better to hope your account gets created in short order. ![]()
My view on managing activation/porting: https://productioncommunity.publicmobile.ca/t5/Getting-Started/BE-PREPARED/m-p/112014
06-21-2017 08:22 PM
hi
i just mailed a mod; hope this gets sorted out. for someone who's debating whether or not to change his primary account to PM, this doesn't generate a lot of confidence. i was prepared to face some delay over porting numbers, but to have to ask for help in order to CREATE an account is somewhat unusual in a telecom company website.
06-21-2017 08:19 PM
will all due respect:
a. that is piss-poor website design, and i speak as a pro;
and
b. no, that did not help.
06-21-2017 08:13 PM
Hey @roniebanerjee
This isn't an issue, it's normal and expected! This particular situation happens when every field's character limit isn't being respected! The character limit is written in red above each field.
Please make sure to not exceed 11 characters for the first name, not more than 18 characters for the last name and not more than 21 characters for the city 🙂
Let us know how that goes 🙂
Marie
06-21-2017 08:11 PM
If you are just reporting the issue; thanks. 👍👍
If you are trying to activate a SIM be sure to turn off any popup/ad blocker.
Still fails, you will need moderator assistance. Send a private message to the moderator team with:
Channel your patient persona. 🙏
06-21-2017 08:08 PM
Have you tried:
-clearing the browser cookies/cache
-using incognito/private browsing mode
-using a different device such as ipad
If that doesn't help, you should send a private message to any moderator listed here:
http://productioncommunity.publicmobile.ca/t5/Knowledge-Base/Updated-Contacting-our-Community-Modera...
Include your phone number, PM SIM card number and e-mail address
and if porting, the phone number you want to port, your account number with your previous carrier, and the authorized name exactly as it appears on that account.
