can not use the internet, although I have enough data
01-26-2023 01:27 AM
01-26-2023 10:40 AM
When you re-set your phone all setting go back to default. Check the data settings on your phone.
01-26-2023 06:05 AM
@dojun8491 - did you just activate with public mobile and have not been able to use data since?
Or, have you been a customer that has been able to use data previously?
If your My Account correctly reflects data left after refreshing the page, then try:
- restart your phone
- toggle into and out of airplane mode
- perform a Reset of the device's Network Settings
- move your sim card to another phone to see if services works
Check your APN settings. For Android phones try editing to this.
https://www.publicmobile.ca/en/on/get-help/articles/what-you-should-do-after-activating
https://www.publicmobile.ca/en/on/get-help/articles/set-up-data-on-an-android-phone
If you have an LG phone it may need a factory reset; but try all other suggestions first before backing up and stuff.
01-26-2023 01:46 AM
Hi @dojun8491
open page inPrivate mode, and in main page click the little circular arrow icon in the bottom right corner to update,
or call *611 press 3 and you need your 4 digit PIN and check it out data usage.
01-26-2023 01:37 AM
Click all the little spinner refresh icons you see lower down to try to get updated proper information. Or use private mode.
You should see a green or red bar indicating plan usage. Then you should see or not see add-ons and their usage. See if your bar is red and full. See if you have any mention of data in add-ons.
01-26-2023 01:29 AM
@dojun8491 wrote:I reset the phone, but still not working.. weird.
The Self Serve site can sometimes give incorrect information about remaining data. I would dial 611 from your phone to double check if how much you have left to use.
