03-14-2019 09:31 PM - edited 01-05-2022 03:43 AM
i am trying to port my number from rogers under my name but public mobile is under my wife name wanna port over the number and keep getting this error if it does not work looks like i am gonna leave public mobile.
erro: We were unable to transfer the phone number you entered. Try one of the following options:
- Make sure you entered your number correctly.
- Select a new number.
- Contact the Public Mobile Community for further assistance.
03-14-2019 10:42 PM
@r_jammu, number porting does not require the sending and receiving accounts to have the same ownership. The only thing required is the acknowledgment that the porting is authorized, meaning the person who owns the number is on board with the porting. With respect to problems porting from Rogers, you have to be careful entering the account number. On the bill the account number is parsed by hyphens. When entering the account number into the porting screen, those hyphens are not be included. Only enter the numbers without spacing. In general, this is the format for entering the sending account number. If the system will let you attempt a port again, give this a try. If the system is not allowing a second attempt, then the moderator team should be contacted for assistance as already suggested.
03-14-2019 09:50 PM
@r_jammu wrote:i am trying to port my number from rogers under my name but public mobile is under my wife name wanna port over the number and keep getting this error if it does not work looks like i am gonna leave public mobile.
You can try later but you can already ask for help to the moderator here... https://productioncommunity.publicmobile.ca/t5/notes/composepage and write moderator_team in send to explain what happened. Waiting time is few hours to 2 days.
03-14-2019 09:47 PM
@r_jammu - at the time you specify the number you want to port, there is no check of account owner, etc. That would only happen after you enter the account information in the form (account number, PIN number IMEI, etc.)
03-14-2019 09:44 PM
@r_jammu It could be an issue with the browser you are using, try Chrome in incognito mode.
