can i use my phone if iam traveling to china and taiwan?
lemur
i will be traveling to asia, and i wanna know if i need to add a new plan to my phone?  if so whick one is the best ?  or do i need to get a new sim card for asia?
7 REPLIES 7
@srlawren$12 per day easy roam
Vs $30 for a SIM (some even cost more as the $35 above link shows)
Then a plan of 500MB is another $30
So Minimum is $60 for a measly 1GB on local carrier
And it shows $0.07 per minute of talk time
srlawren
@kav2001c at $12 per 24 hours on international Easy Roam [capped to $150 per billing cycle], unless your trip is pretty short, you're likely going to spend a LOT more on Easy Roam than a local SIM.
I doubt it
Its cheaper to use Koodo easy roam than it is to buy a Chinese SIM
Telus even has *FREE* roaming included in many of their premium plans
Not very likely Public would end up costing even more
Too many people always assuming Canadian roaming rates are terrible
I even posted a link to Chinese provider right above your response
@dna2016 wrote:
Even if PM offered roaming in asia, I'm sure it would have been much cheaper just to get a local SIM over there anyways.
dna2016
@lemur, PM only provides North America roaming, so if you're visiting asia then you'll need to make sure your phone is unlocked and works on the frequency there, then get a local SIM over there.
kav2001c
Can always grab a Chinese prepay SIM while over there
https://www.china-mobile-phones.com/china-3g-sim-card.html
RobertQc
@lemurPublic mobile uses Bell/Telus network in Canada, and AT&T/T-Mobile (with a roaming package) in the U.S.A
Your service will not work outside USA/Canada.
There are many pre-paid asia sim cards you can buy 1 time for your trip.
Dunkgirl
@lemurNo. Public mobile is Canada only and extends to U.S.A with a US roaming package.
If you go outside USA/Canada you will need a new sim card by another provider. Make sure your phone supports the network frequencies of that provider. Not all phones from Canada will work in Asia.
