02-13-2021 04:22 PM - edited 01-06-2022 02:06 AM
02-13-2021 05:16 PM
If you're going to add another account, be sure to use your referral code from your existing account to save yourself the referral and referee rewards.
It is found here:
02-13-2021 04:28 PM
02-13-2021 04:26 PM
@jenkins2020 Unfortunately, PM do not allow multiple numbers within the same account. You will need another sim and another account.
02-13-2021 04:24 PM
You can have as many accounts as you wish, but only one phone number can be in each account.
02-13-2021 04:23 PM - edited 02-13-2021 04:25 PM
@jenkins2020 Unfortunately no. You need a separate email for each separate account for each separate number. You can use email aliases if your service supports it (this is effectively using the same email address for multiple accounts).
